请问哪位高手有英文版的网架施工验收标准方面的资料
Fatcat
请问哪位高手有英文版的国标网架施工验收标准方面的资料。现在有一个国外投标项目急用。
wjwjwj
2005-7-19 21:40
SPACEFRAME DESIGN SPECIFICATIONS
1. GENERAL
1.0 Codes & Standards
1.1 Spaceframe System Manual
1.2 Chinese GB Material Standards
1.3 ISO Material Standards
1.4 Chinese Design Standards
Loadings: GB 50009-2001
Steel structural design: GB 50017-2003
2.0 Material Strength
2.1 Pipes & cones to GB/T 700 Q235
Min. yield strength: 235 N/mm2
Min. tensile strength: 375 N/mm2
2.2 High-strength bolts to ISO 898-1 class 10.9
Min. yield strength: 940 N/mm2
Min. tensile strength: 1040 N/mm2
2.3 Nodes to GB/T 699 45# in normalized condition
Min. yield strength: 275 N/mm2
Min. tensile strength: 560 N/mm2
2.4 Sleeves to GB/T 700 Q345
Min. yield strength: 345 N/mm2
Min. tensile strength: 490 N/mm2
3.0 Slenderness ratio
The slenderness ratio of all members shall not exceed 180.
4.0 Software
Software: 3-dimensional spaceframe analysis and design (code checking) program from Beijing iKon Tech: SFCAD2000.
2. DESIGN LOADINGS
(1) DL: Dead Load
Roof cladding
Purlins
0.10 kN/m2
0.10 kN/m2
0.20 kN/m2
Spaceframe self weight to be taken the gravity of pipe multiply by 1.2 to include the weight of spaceframe nodes.
(2) LL: Live Load 1.00 kN/m2
(3) WL: Wind Load 0.70 kN/m2
Every 10 degrees as wind load direction WL1-WL36
3. LOAD COMBINATIONS: 182
LOAD COMBINATION 1: 1.2*DL*1.0+1.4*LL*1.0
LOAD COMBINATION 2: 1.35*DL*1.0+1.4*LL*0.7
LOAD COMBINATION 3: 1.0*DL*1.0+1.4*WL-1*1.0
LOAD COMBINATION 4: 1.0*DL*1.0+1.4*WL-2*1.0
LOAD COMBINATION 5: 1.0*DL*1.0+1.4*WL-3*1.0
LOAD COMBINATION 6: 1.0*DL*1.0+1.4*WL-4*1.0
LOAD COMBINATION 7: 1.0*DL*1.0+1.4*WL-5*1.0
LOAD COMBINATION 8: 1.0*DL*1.0+1.4*WL-6*1.0
LOAD COMBINATION 9: 1.0*DL*1.0+1.4*WL-7*1.0
LOAD COMBINATION 10: 1.0*DL*1.0+1.4*WL-8*1.0
LOAD COMBINATION 11: 1.0*DL*1.0+1.4*WL-9*1.0
LOAD COMBINATION 12: 1.0*DL*1.0+1.4*WL-10*1.0
LOAD COMBINATION 13: 1.0*DL*1.0+1.4*WL-11*1.0
LOAD COMBINATION 14: 1.0*DL*1.0+1.4*WL-12*1.0
LOAD COMBINATION 15: 1.0*DL*1.0+1.4*WL-13*1.0
LOAD COMBINATION 16: 1.0*DL*1.0+1.4*WL-14*1.0
LOAD COMBINATION 17: 1.0*DL*1.0+1.4*WL-15*1.0
LOAD COMBINATION 18: 1.0*DL*1.0+1.4*WL-16*1.0
LOAD COMBINATION 19: 1.0*DL*1.0+1.4*WL-17*1.0
LOAD COMBINATION 20: 1.0*DL*1.0+1.4*WL-18*1.0
LOAD COMBINATION 21: 1.0*DL*1.0+1.4*WL-19*1.0
LOAD COMBINATION 22: 1.0*DL*1.0+1.4*WL-20*1.0
LOAD COMBINATION 23: 1.0*DL*1.0+1.4*WL-21*1.0
LOAD COMBINATION 24: 1.0*DL*1.0+1.4*WL-22*1.0
LOAD COMBINATION 25: 1.0*DL*1.0+1.4*WL-23*1.0
LOAD COMBINATION 26: 1.0*DL*1.0+1.4*WL-24*1.0
LOAD COMBINATION 27: 1.0*DL*1.0+1.4*WL-25*1.0
LOAD COMBINATION 28: 1.0*DL*1.0+1.4*WL-26*1.0
LOAD COMBINATION 29: 1.0*DL*1.0+1.4*WL-27*1.0
LOAD COMBINATION 30: 1.0*DL*1.0+1.4*WL-28*1.0
LOAD COMBINATION 31: 1.0*DL*1.0+1.4*WL-29*1.0
LOAD COMBINATION 32: 1.0*DL*1.0+1.4*WL-30*1.0
LOAD COMBINATION 33: 1.0*DL*1.0+1.4*WL-31*1.0
LOAD COMBINATION 34: 1.0*DL*1.0+1.4*WL-32*1.0
LOAD COMBINATION 35: 1.0*DL*1.0+1.4*WL-33*1.0
LOAD COMBINATION 36: 1.0*DL*1.0+1.4*WL-34*1.0
LOAD COMBINATION 37: 1.0*DL*1.0+1.4*WL-35*1.0
LOAD COMBINATION 38: 1.0*DL*1.0+1.4*WL-36*1.0
LOAD COMBINATION 39: 1.2*DL*1.0+1.4*WL-1*1.0
LOAD COMBINATION 40: 1.2*DL*1.0+1.4*WL-2*1.0
LOAD COMBINATION 41: 1.2*DL*1.0+1.4*WL-3*1.0
LOAD COMBINATION 42: 1.2*DL*1.0+1.4*WL-4*1.0
LOAD COMBINATION 43: 1.2*DL*1.0+1.4*WL-5*1.0
LOAD COMBINATION 44: 1.2*DL*1.0+1.4*WL-6*1.0
LOAD COMBINATION 45: 1.2*DL*1.0+1.4*WL-7*1.0
LOAD COMBINATION 46: 1.2*DL*1.0+1.4*WL-8*1.0
LOAD COMBINATION 47: 1.2*DL*1.0+1.4*WL-9*1.0
LOAD COMBINATION 48: 1.2*DL*1.0+1.4*WL-10*1.0
LOAD COMBINATION 49: 1.2*DL*1.0+1.4*WL-11*1.0
LOAD COMBINATION 50: 1.2*DL*1.0+1.4*WL-12*1.0
LOAD COMBINATION 51: 1.2*DL*1.0+1.4*WL-13*1.0
LOAD COMBINATION 52: 1.2*DL*1.0+1.4*WL-14*1.0
LOAD COMBINATION 53: 1.2*DL*1.0+1.4*WL-15*1.0
LOAD COMBINATION 54: 1.2*DL*1.0+1.4*WL-16*1.0
LOAD COMBINATION 55: 1.2*DL*1.0+1.4*WL-17*1.0
LOAD COMBINATION 56: 1.2*DL*1.0+1.4*WL-18*1.0
LOAD COMBINATION 57: 1.2*DL*1.0+1.4*WL-19*1.0
LOAD COMBINATION 58: 1.2*DL*1.0+1.4*WL-20*1.0
LOAD COMBINATION 59: 1.2*DL*1.0+1.4*WL-21*1.0
LOAD COMBINATION 60: 1.2*DL*1.0+1.4*WL-22*1.0
LOAD COMBINATION 61: 1.2*DL*1.0+1.4*WL-23*1.0
LOAD COMBINATION 62: 1.2*DL*1.0+1.4*WL-24*1.0
LOAD COMBINATION 63: 1.2*DL*1.0+1.4*WL-25*1.0
LOAD COMBINATION 64: 1.2*DL*1.0+1.4*WL-26*1.0
LOAD COMBINATION 65: 1.2*DL*1.0+1.4*WL-27*1.0
LOAD COMBINATION 66: 1.2*DL*1.0+1.4*WL-28*1.0
LOAD COMBINATION 67: 1.2*DL*1.0+1.4*WL-29*1.0
LOAD COMBINATION 68: 1.2*DL*1.0+1.4*WL-30*1.0
LOAD COMBINATION 69: 1.2*DL*1.0+1.4*WL-31*1.0
LOAD COMBINATION 70: 1.2*DL*1.0+1.4*WL-32*1.0
LOAD COMBINATION 71: 1.2*DL*1.0+1.4*WL-33*1.0
LOAD COMBINATION 72: 1.2*DL*1.0+1.4*WL-34*1.0
LOAD COMBINATION 73: 1.2*DL*1.0+1.4*WL-35*1.0
LOAD COMBINATION 74: 1.2*DL*1.0+1.4*WL-36*1.0
LOAD COMBINATION 75: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-1*0.6
LOAD COMBINATION 76: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-2*0.6
LOAD COMBINATION 77: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-3*0.6
LOAD COMBINATION 78: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-4*0.6
LOAD COMBINATION 79: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-5*0.6
LOAD COMBINATION 80: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-6*0.6
LOAD COMBINATION 81: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-7*0.6
LOAD COMBINATION 82: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-8*0.6
LOAD COMBINATION 83: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-9*0.6
LOAD COMBINATION 84: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-10*0.6
LOAD COMBINATION 85: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-11*0.6
LOAD COMBINATION 86: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-12*0.6
LOAD COMBINATION 87: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-13*0.6
LOAD COMBINATION 88: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-14*0.6
LOAD COMBINATION 89: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-15*0.6
LOAD COMBINATION 90: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-16*0.6
LOAD COMBINATION 91: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-17*0.6
LOAD COMBINATION 92: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-18*0.6
LOAD COMBINATION 93: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-19*0.6
LOAD COMBINATION 94: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-20*0.6
LOAD COMBINATION 95: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-21*0.6
LOAD COMBINATION 96: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-22*0.6
LOAD COMBINATION 97: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-23*0.6
LOAD COMBINATION 98: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-24*0.6
LOAD COMBINATION 99: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-25*0.6
LOAD COMBINATION 100: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-26*0.6
LOAD COMBINATION 101: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-27*0.6
LOAD COMBINATION 102: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-28*0.6
LOAD COMBINATION 103: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-29*0.6
LOAD COMBINATION 104: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-30*0.6
LOAD COMBINATION 105: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-31*0.6
LOAD COMBINATION 106: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-32*0.6
LOAD COMBINATION 107: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-33*0.6
LOAD COMBINATION 108: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-34*0.6
LOAD COMBINATION 109: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-35*0.6
LOAD COMBINATION 110: 1.2*DL*1.0+1.4*LL*1.0+1.4*WL-36*0.6
LOAD COMBINATION 111: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-1*0.6
LOAD COMBINATION 112: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-2*0.6
LOAD COMBINATION 113: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-3*0.6
LOAD COMBINATION 114: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-4*0.6
LOAD COMBINATION 115: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-5*0.6
LOAD COMBINATION 116: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-6*0.6
LOAD COMBINATION 117: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-7*0.6
LOAD COMBINATION 118: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-8*0.6
LOAD COMBINATION 119: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-9*0.6
LOAD COMBINATION 120: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-10*0.6
LOAD COMBINATION 121: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-11*0.6
LOAD COMBINATION 122: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-12*0.6
LOAD COMBINATION 123: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-13*0.6
LOAD COMBINATION 124: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-14*0.6
LOAD COMBINATION 125: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-15*0.6
LOAD COMBINATION 126: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-16*0.6
LOAD COMBINATION 127: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-17*0.6
LOAD COMBINATION 128: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-18*0.6
LOAD COMBINATION 129: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-19*0.6
LOAD COMBINATION 130: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-20*0.6
LOAD COMBINATION 131: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-21*0.6
LOAD COMBINATION 132: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-22*0.6
LOAD COMBINATION 133: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-23*0.6
LOAD COMBINATION 134: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-24*0.6
LOAD COMBINATION 135: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-25*0.6
LOAD COMBINATION 136: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-26*0.6
LOAD COMBINATION 137: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-27*0.6
LOAD COMBINATION 138: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-28*0.6
LOAD COMBINATION 139: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-29*0.6
LOAD COMBINATION 140: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-30*0.6
LOAD COMBINATION 141: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-31*0.6
LOAD COMBINATION 142: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-32*0.6
LOAD COMBINATION 143: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-33*0.6
LOAD COMBINATION 144: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-34*0.6
LOAD COMBINATION 145: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-35*0.6
LOAD COMBINATION 146: 1.35*DL*1.0+1.4*LL*0.7+1.4*WL-36*0.6
LOAD COMBINATION 147: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-1*1.0
LOAD COMBINATION 148: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-2*1.0
LOAD COMBINATION 149: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-3*1.0
LOAD COMBINATION 150: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-4*1.0
LOAD COMBINATION 151: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-5*1.0
LOAD COMBINATION 152: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-6*1.0
LOAD COMBINATION 153: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-7*1.0
LOAD COMBINATION 154: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-8*1.0
LOAD COMBINATION 155: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-9*1.0
LOAD COMBINATION 156: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-10*1.0
LOAD COMBINATION 157: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-11*1.0
LOAD COMBINATION 158: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-12*1.0
LOAD COMBINATION 159: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-13*1.0
LOAD COMBINATION 160: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-14*1.0
LOAD COMBINATION 161: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-15*1.0
LOAD COMBINATION 162: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-16*1.0
LOAD COMBINATION 163: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-17*1.0
LOAD COMBINATION 164: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-18*1.0
LOAD COMBINATION 165: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-19*1.0
LOAD COMBINATION 166: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-20*1.0
LOAD COMBINATION 167: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-21*1.0
LOAD COMBINATION 168: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-22*1.0
LOAD COMBINATION 169: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-23*1.0
LOAD COMBINATION 170: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-24*1.0
LOAD COMBINATION 171: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-25*1.0
LOAD COMBINATION 172: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-26*1.0
LOAD COMBINATION 173: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-27*1.0
LOAD COMBINATION 174: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-28*1.0
LOAD COMBINATION 175: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-29*1.0
LOAD COMBINATION 176: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-30*1.0
LOAD COMBINATION 177: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-31*1.0
LOAD COMBINATION 178: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-32*1.0
LOAD COMBINATION 179: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-33*1.0
LOAD COMBINATION 180: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-34*1.0
LOAD COMBINATION 181: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-35*1.0
LOAD COMBINATION 182: 1.2*DL*1.0+1.4*LL*0.25+1.3*EL-36*1.0
4. STRUCTURAL ANALYSIS:
All the members of the spaceframe will be code checked according to GB 50017-2003 for member tension and compression in the worst load combination listed above. Optimized pipe section will be auto selected thru an iterated method by software SFCAD.
