台湾膜结构建筑
skyland
1.Myao Li Arena(2000)
This multi-purpose arena has a unique membrane roof that measures 82.8m by 82.5m. The arch reises from ground level to 42.4 meters at the center, which splits the roof into two halves. The sides of the roof are formed by concrete beams at a much lower elevation, between 15.0 meters above ground to 20.0 meters. Ridge and valley cables span between the arch and the longitudinal beams to create the saw-tooth form. Longitudinal cables are added to complete the cable network. Total fabric area is 6,200 square meters.
skyland
2002-12-16 00:57
1.Myao Li Arena(2)
skyland
2002-12-16 00:58
1.Myao Li Arena(3)
skyland
2002-12-16 01:00
2.Ja-Yi Sports Gymnasium(1996)
This sports facility is covered by a distinctive tensile membrane roof spanning 56.9m x 80.5 m (187 ft x 264 ft ). The gymnasium seats 4,000 spectators for court sports. The high profile tensile structure is a major element in the facility's architecture.
skyland
2002-12-16 01:02
2.Ja-Yi Sports Gymnasium(2)
skyland
2002-12-16 01:07
2.Ja-Yi Sports Gymnasium(3)
skyland
2002-12-16 01:08
3.Ja-Yi Track and Field Grandstand Canopy(1996)
This structure covers one of the grandstands of the track and field stadium. The membrane canopy covers 2,900 m2 (31,200 ft2) and cantilevers 21.5 m (70 ft). The structure is designed to resist significant uplift from typhoon winds.
skyland
2002-12-16 01:12
3.Ja-Yi Track and Field Grandstand Canopy(2)
skyland
2002-12-16 01:15
3.Ja-Yi Track and Field Grandstand Canopy(3)
skyland
2002-12-16 01:17
4.Taoyuan Sports Arena(1993)
The sports arena seats 15,000 spectators for a variety of sports and entertainment events. The facility is covered by a 136.2 m diameter tensegrity dome using the Geiger Cabledome system. The roof structure was engineered to achieve an unprecedented rapid erection/installation as dictated by Project requirements. The structure is clad with a prestressed Teflon[$#8482] coated Fiberglas[$reg] composite membrane. The roof membrane is translucent allowing sufficient natural light to preclude the necessity of artificial lighting for most daylight events. The award-winning roof structure was design/built by Taiyo Kogyo, Birdair,Inc. and Geiger Engineers. The roof was completely engineered, fabricated and erected in nominally 14 months.
skyland
2002-12-16 01:19
4.Taoyuan Sports Arena(2)
skyland
2002-12-16 01:20
4.Taoyuan Sports Arena(3)
SILICON
2002-12-20 14:04
花莲体育馆
SILICON
2002-12-20 14:49
花体2
yangjunok
2002-12-31 17:24
花莲体育馆的膜结构我知道,我见过上海济丰公司的资料,这个工程是他们的项目。好象他们的网站上有:www.cm-spatialtech.com
