1. Tensile strength of the plate
2. Bearing of the pinned connections: pin itselt and the base plate.
3. Any components that transmit forces through bearing on each other
4. Welding
Basically, all components along the load path need to be checked one by one. A reasonable configuration and simple connection will lead to easy design and elegant toggles.
